Question How to add BB class attribute code to URL in Category Description?
13 years 11 months ago - 13 years 11 months ago #137883 by nemmar
I have a Kunena 2.0.3 forum and I need to add a class attribute to the BB url code in the Category Description text area.
I can get a normal URL to work with the BB code: Link Text
But I need to add a class attribute to that URL. Does anyone know what the BB code should look like to do this?
Thanks for any advice!
Last edit: 13 years 11 months ago by nemmar.
13 years 11 months ago - 13 years 11 months ago #137885 by sozzled
I don't think that you can selectively assign HTML class attributes to specific URLs. You can change the CSS attributes for all URLs on your forum, sure. But selectively? I don't think that it's possible in the current version of Kunena. You would need to design a way to do this by modifying the Kunena BBcode parser functions and add additional options to specify extra HTML class attribute characteristics.
The simple fact is that you cannot add HTML information in BBcode. This limitation also extends to the Category Description. Depends also what you want to define in the HTML class. If it's just a matter of changing the colour of the HTML <A> then that's easy. Use the "color" attribute.
Good luck in finding out how to do this. It may be useful for others. :)
Last edit: 13 years 11 months ago by sozzled.
