Question Add File Not Working
13 years 11 months ago #137729 by rwoonacott
I have a website www.mypitblind.com and what is going on is that we updated the forum not long ago, and ever since then we cannot Add A File to the forum its self. YOu can click on it, and you can pick a photo out but once you pick the photo you cannot see the upload at all, it is like if you click on the whole box it comes up with a image to pick.
Any ideas?
13 years 11 months ago - 13 years 11 months ago #137742 by sozzled
Replied by sozzled on topic Add File Not Working
I'm not quite sure that I understand what you mean by "it is like if you click on the whole box it comes up with a image to pick". Is it possible for you to show us a picture of what happens, please?
I could not find Kunena installed on your website.
Last edit: 13 years 11 months ago by sozzled.
13 years 11 months ago #137744 by Mortti
Replied by Mortti on topic Add File Not Working
sozzled wrote: I could not find Kunena installed on your website.
That "Randy's Club House" menu link goes to Kunena when browser is loaded about week :)
Chrome tool give couple error in there screencast.com/t/tRehVOAcSm
13 years 11 months ago #137746 by sozzled
Mystery solved. Thanks, Mortti.
Yes, I now see where the link on the site is supposed to go to the Kunena forum but it takes an interminable age before the link actually responds. There looks to be something a little amiss with routing on your site - a lot of extraneous "activity", perhaps - that results in the message at the foot of the page stating "Time to create page: 180.021 seconds" 3 minutes to generate a web page? That's unheard of!
Performance issues are one thing (and they may or may not be involved) but it may help to address those mattes by seeing your configuration report. I still think it would be a good idea if we could see a picture of "it is like if you click on the whole box it comes up with a image to pick". Thanks
13 years 11 months ago #137770 by rwoonacott
Replied by rwoonacott on topic Add File Not Working
sozzled wrote: Mystery solved. Thanks, Mortti.
HOPE THIS HELPS!!
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 300M
Joomla default template details : rt_crystalline_j15 | author: RocketTheme, LLC | version: 1.5.7 | creationdate: August 19, 2010
Kunena default template details : Crimea | author: Kunena Team | version: 1.6.0 | creationdate: 2010-07-04
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Third-party components: Jomsocial 2.6.2
Plugins: None
13 years 11 months ago #137778 by sozzled
Templates designed for very old versions of Kunena will cause problems and you are advised not to use them (or, at least, check for a solution with the people who designed those things). Did you read about this in the release notes when you upgraded to K 2.0.3?
Your Joomla menu has conflicting menu items that will redirect in ways that may not be resolved. The more easy solution is to rebuild your Kunena menu (use the standard menu that comes with Kunena) and check to see if this solves your current problem first. Then, if that works, you can change the menu later - checking, of course, that you don't "break" anything.
Why have you enabled the Kunena - Community Builder plugin?
