configuration report
Question Seeking help from people who use Vimeo videos and Kunena
13 years 5 months ago #137637
by MaiiQ
Seeking help from people who use Vimeo videos and Kunena was created by MaiiQ
Hi! I have a big problem in my site. If I insert the tag video before a external link, this link not work. Only put a normal text. If I put the tag after the link, all works correct.
My site is: www.maiiqmusic.com
Please help! Thanks in advance!
13 years 5 months ago #137706
by MaiiQ
Replied by MaiiQ on topic Seeking help from people who use Vimeo videos and Kunena
I try in a lot of kunena forums and all the same.
Sorry for repeat post but the other was not in the right category.
13 years 5 months ago - 13 years 5 months ago #137714
Replied by sozzled on topic Seeking help from people who use Vimeo videos and Kunena
*** Topics merged ***
Please do not repeat your question (by creating more than one topic) or if you do not receive a response as soon as you ask it. I don't actually know the answer to your question. I do not even know if this problem you are having is something missing in Kunena by design.
What do you mean, "If I insert the tag video before a external link, this link not work. Only put a normal text; if I put the tag after the link, all works correct". If it "all works correctly" I don't understand the problem. Can you explain that to us, please? Have you tried making a test posting in our Playground category on this site here?
Last edit: 13 years 5 months ago by sozzled.
13 years 5 months ago - 13 years 5 months ago #137720
by MaiiQ
Last edit: 13 years 5 months ago by MaiiQ.
13 years 5 months ago - 13 years 5 months ago #137721
Yes, I understand. You want to display videos from YouTube.com. For YouTube videos you do not need the video BBcode tag. Simply enter the URL and the video player will automatically be embedded for you. Therefore if you simply type the following
This is what you will see
Does this help?
http://www.youtube.com/watch?v=paQscwbbDVE&feature=youtu.be
Does this help?
13 years 5 months ago #137722
by MaiiQ
Yes I know that. But the the problem happens with all video servers (vimeo,...)
The auto-integration with youtube its not my solution...
Time to create page: 0.276 seconds
