Question Seeking help from people who use Vimeo videos and Kunena
13 years 11 months ago #137637 by MaiiQ
Hi! I have a big problem in my site. If I insert the tag video before a external link, this link not work. Only put a normal text. If I put the tag after the link, all works correct.
My site is: www.maiiqmusic.com
Please help! Thanks in advance!
13 years 11 months ago #137706 by MaiiQ
I try in a lot of kunena forums and all the same.
Sorry for repeat post but the other was not in the right category.
13 years 11 months ago - 13 years 11 months ago #137714 by sozzled
*** Topics merged ***
Please do not repeat your question (by creating more than one topic) or if you do not receive a response as soon as you ask it. I don't actually know the answer to your question. I do not even know if this problem you are having is something missing in Kunena by design.
What do you mean, "If I insert the tag video before a external link, this link not work. Only put a normal text; if I put the tag after the link, all works correct". If it "all works correctly" I don't understand the problem. Can you explain that to us, please? Have you tried making a test posting in our Playground category on this site here?
Last edit: 13 years 11 months ago by sozzled.
13 years 11 months ago - 13 years 11 months ago #137720 by MaiiQ
Sorry!
I'll explain better with pictures.
This is the problem: I put a video with the kunena tag ["video][/video] (without "), and after the video I put a external link and this not work (normal text).
But, if I put the tag before the link, works good!
You understand now?
Last edit: 13 years 11 months ago by MaiiQ.
13 years 11 months ago - 13 years 11 months ago #137721 by sozzled
Yes, I understand. You want to display videos from YouTube.com. For YouTube videos you do not need the video BBcode tag. Simply enter the URL and the video player will automatically be embedded for you. Therefore if you simply type the following
http://www.youtube.com/watch?v=paQscwbbDVE&feature=youtu.be
This is what you will see
Does this help?
13 years 11 months ago #137722 by MaiiQ
Yes I know that. But the the problem happens with all video servers (vimeo,...)
The auto-integration with youtube its not my solution...
