Question php 5.3 or higher forum wont work
13 years 11 months ago #137323 by maorcg
I download kunena 2.0.3 today and after it upgrade my 1.7.0 kunena the forum stop from working and i got error say
Content Encoding Error
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression."
and i tray to use php 5.3 and 5.4 both wont work and 5.2 because it no supported on 2.0.3
then i got back to kunena 1.7 and still didn't change back the php 5.3 and my forum didnt work
it only work wan i use php 5.2 my host is bluehost
I want to upgrade to 2.0.3 how do i get the forum to work on my server
i use joomla 2.5
server bluehost
my forum site is
forum
now Im back to 1.7 kunena and 5.2 php
thank you for the help
TNX for the help
13 years 11 months ago #137328 by sozzled
G'day, maorcg, and welcome to Kunena.
According to the release notes for K 2.0.3 and K 2.0 Technical Requirements , K 2.0.3 should work with PHP 5.3. The development team has not fully tested K 2.0.3 with all versions of PHP and there are a number of versions of PHP that have problems. We know, for example, that some versions of PHP 5.4 are defective.
Having said this, this website uses one of the latest versions of PHP 5.3 that is available and we are not experiencing any problems running K 2.0.3 here. Even on my own websites, where I am using PHP 5.3, I do not have any problems like the one you mentioned.
I am not sure if the message "Content Encoding Error: The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression" is related to PHP or whether it's related to an extra piece of compression software that you've installed on your website. Perhaps if you knew more about your K 2.0.3 website (your configuration report is a good start) we may know more.
The release notes and the technical requirements articles that I mentioned above state what you need. Whether or not your webhosting provider has made other changes or whether you have installed other software that conflicts with Joomla/Kunena, that's a more difficult issue for anyone to advise you about.
From the sounds of things, Bluehost is not giving you the service that you need and you may be better advised to look at other webhosting solutions. Good luck.
13 years 11 months ago - 13 years 11 months ago #137344 by maorcg
Hi and Thank you For the help,
i dont use in my site in any compression or kunena plugin
the wired thing is that after i change to php 5.3 or 5.3 from 5.2 even the 1.7. kunena stop from working and kunena 2.0.0 wont work at all with any of the php on my server and i get the same msg compression error.
Technical Requirements:
PHP 5.2.4+ or 5.3.0+ B)
MySQL 5.0.3+ or 5.1.0+ or 5.5.0+ B)
Joomla 1.5.26+ or 2.5.4+ B)
max_execution_time >= 30 B)
memory_limit >= 16M i use 60 (php 5.2) B)
safe_mode = off B)
upload_max_filesize >= 3M 10m B)
so i think i have all the Requirements
there is any host company that you know that work good with kunena ?
or i can give you account to my joomla site and the server to test bluehost with kunena 2
thank for the help
Last edit: 13 years 11 months ago by maorcg.
