Question Soundcloud plugin?
14 years 4 days ago #136627 by jpc0480
Soundcloud plugin? was created by jpc0480
Is there an easy way to incorporate a Soundcloud plugin much similar to the way Kunena handles YouTube? If a users posts a YouTube link even without using the video toolbar Kunena picks it up and displays the video.
Is there a simple way to add this to the Kunena code or incorporate some other way?
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
14 years 3 days ago #136632 by Jiminimonka
Replied by Jiminimonka on topic Soundcloud plugin?
You can use AllVideo, and probably the Joomla Soundcloud plugin within Kunena using the {} syntax within Kunena messages.
A quick search would have turned up the answer to this question.
www.kunena.org/forum/search?q=soundcloud&childforums=1
Please read the FAQ.
Only one question per topic.
14 years 3 days ago - 14 years 3 days ago #136633 by jpc0480
Replied by jpc0480 on topic Soundcloud plugin?
Well I found this in another thread:
In the file / administrator / components / com_kunena / libraries / bbcode / bbcode.php, this is where your new bbcode will be managed. On line 819 add something like this:
'soundcloud' => array(
'mode' => BBCODE_MODE_LIBRARY,
'method' => 'DoSoundcloud',
'allow_in' => array('listitem', 'block', 'columns'),
'class' => 'block',
'content' => BBCODE_PROHIBIT,
'plain_start' => "[soundcloud]",
'plain_end' => "\n",
At the end of the file you add your function (The problem is here, am getting an error with the following):
function DoSoundcloud($bbcode, $action, $name, $default, $params, $content) { if ($action == BBCODE_CHECK) return true; return "<object height =" 81 "width =" 100 % "> <param name =" movie "value =" http : / / player.soundcloud.com / player.swf? url = {$ content} & g = bb "> </ param> <param name="allowscriptaccess" value="always"> </ param> <embed allowscriptaccess =" always "height =" 81 "src ="
. swf? url = {$ content} & g = bb "type =" application / x-shockwave-flash "width =" 100% "> </ embed> </ object> <a href =" {$ content} "> {$ content} </ a>"; }
In the following file: / components / com_kunena / template / blue_eagle / html / topic / edit_editor.php you'll add the button to your new bbcode
This is all related to a guide on soundcloud:
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
Last edit: 14 years 3 days ago by jpc0480.
14 years 3 days ago - 14 years 3 days ago #136634 by sozzled
Replied by sozzled on topic Soundcloud plugin?
jpc0480 wrote: Well I found this in another thread...
What is not clear from the Soundcloud site is what "flavour" of BBcode we are discussing. It is my guess is that the solution you found was for a different kind of forum. In other words, the approach you've written about has not been tested in (and is therefore not appropriate for) K 2.0.2.
BBcode is proprietary. There is no "universal" implementation of BBcode.
Last edit: 14 years 3 days ago by sozzled.
14 years 3 days ago #136664 by jpc0480
I found it here: kunena.aide-joomla.com/forum/kunena-2-0/...ud-dans-kunena#12285
It's in French, but if you have a translator plugin for your browser it will translate. Looks like the post is from a dev at Kunena?
Kunena 3.0.4
CB 1.9.1
Joomla 2.5.18
