Question Ok, 1 question here then :0)
14 years 6 days ago #136621 by ScotMk
I am not using 3rd party templates as I cannot install them for some reason.
I am using standard instal, template. Wheni out in a new colour in template settings it does not do anything.
3) For "custom colours" read the FAQs page. We do not answer questions on this forum about third-party templates; those are matters that you need to take up with the person who built such things.
14 years 6 days ago - 14 years 6 days ago #136624 by sozzled
It is not entirely clear to me what is the specific question you are trying to ask. It may benefit you to read How To Ask Questions The Smart Way
If I have correctly understood your current situation, you would like assistance installing a third-party template in Kunena. Is that correct?
As I mentioned in another topic , managing your Kunena template is effected by using the Kunena Template Manager. The Kunena Template Manager is the place where you install other [3rd-party] templates. Do not try to install templates using the Joomla Extension Manager; that method will not work. If, however, certain 3rd-party products written for Kunena do not work this way then that's something you should probably discuss with the people who wrote the product that you are having problems with.
Colours, font-styles, etc. used in Kunena are overridden by your Joomla site template. If this is what is happening in your case then you should read My Joomla site template makes a mess of Kunena ...
I hope this helps. :)
Last edit: 14 years 6 days ago by sozzled.
