Idea How To: Kunena and Gantry 4 Responsive Templates (e.g. Rockettheme Metropolis)
14 years 2 weeks ago - 14 years 2 weeks ago #136189 by Jiminimonka
If you find that your forum is missing the Views and Replies tables in categories when using a Gantry 4 Joomla template, such as Metropolis with Responsive mode enabled, then this might be the solution.
Open Notepad++ or some other text editor and paste in the following code.
@media only screen and (min-width: 960px) { #Kunena td.visible-desktop, #Kunena td.visible-desktop { display: table-cell !important; } }
Save the file as template-custom.less
FTP it to your joomla server folder /templates/templatename/less
Clear the cache, clear your LESS cache in the Gantry template manager and the problem should be resolved.
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 2 weeks ago by Jiminimonka.
The following user(s) said Thank You: A. Wayne Webb, Katannah
13 years 11 months ago - 13 years 11 months ago #137814 by A. Wayne Webb
Thanks for the attempt Jiminimonka. I found your posting while trying to figure out why when using Metropolis I get a dreaded "Loading BBCode editor... " It appears to be that some javascript file is not loading. I think it has to do with the template because I'm having similar problems with redShop not running correctly.
That is when I found your kindly proffered posting. In the case of your kindly offered tip it did not work for me on the test site I am working on. If you so desire you an view the site here . You can see the redShop errors here .
While I have thoroughly enjoyed RT for several years, now this Responsive stuff is a royal pain in the posterior.
Cordially
Last edit: 13 years 11 months ago by A. Wayne Webb.
Time to create page: 0.101 seconds
