Question Aphotic II 1.6.3 + K 2.0.2: Spoiler does not work
14 years 2 weeks ago #136324 by MfGLucker
Here you can get the update for the aphotic template compatible with kunena 2.0.x
Sammle erst die Fakten, dann kannst du sie verdrehen, wie es dir passt.
Mark Twain
14 years 2 weeks ago #136325 by MfGLucker
if you still have the problem with no content in your spoiler, try following settings.
Joomla Standard Template
Kunena Blue Eagle 2.0 Template
No SEO in Joomla also in Kunena.
Try it out.
Mark Twain
14 years 1 week ago #136643 by queenvio
I tryed it but it dont work, the same think
14 years 1 week ago #136644 by TKtemp
you have two js errors on this page
TypeError: Fx.Styles is not a constructor
...ew Fx.Styles(element, {duration:550, wait:false, transition: Fx.Transitions.Expo...
in hover.js file at line 8 which is connected to your Menu Module.
When you solve that errors spoiler will probably works as expected.
