Question personal text truncated?
14 years 1 month ago #135207 by ruud
in Kunena config I set the length of the personal text field to 550. But... it always gets truncated at 255? I believe this is because it is datatype 'tinytext'.
If so then there should be a warning or a limit in config :)
Is that something that can be changed (made larger to hold more characters)?
My website uses the personal text to pull author information into an article.
regards,
Ruud.
sharing = caring
14 years 1 month ago #135221 by sozzled
Replied by sozzled on topic personal text truncated?
Good questions but I don't know all the answers.
If the database column is defined as type tinytext then, as we know , you are limited to a maximum of 255 characters. Perhaps it would be useful if attempts to increase beyond this amount came with the warning that you suggest or (better still) if the explanatory notes in the configuration were expanded to include the extra information.
As far as changing the database so that you could store more information, that's a whole different matter. You could possibly modify the database column but this could cause other problems that neither of us can anticipate at this time. Just a suggestion.
