Question Main menu not visible as active
14 years 1 month ago #134497 by Ewoudv
Hi there,
Due to the way the Kunena menu is created, the active main menu is not visible as such. Kunena uses a menu-item alias and this is in fact a link to a page. I am not a specialist but I read that on this page on the official joomla website.
Actually, you have the same problem on your site. Just take a look at the main menu and you will see that 'Forum' is not visible as active. Just click for example Home and you will see a blue line above Home, meaning that Home is the active menu.
Is there a way to get the Main menu Forum to show as active?
Regards,
Ewoud
14 years 2 weeks ago #136117 by Ewoudv
Does anybody have some thoughts about this?
Hopefully the Kunena team can find some solution for this.
