configuration report
Sticky Edit, hide, disable or translate menu items in Kunena (e.g. rules, help, search)
13 years 8 months ago #139900
by nuno.n
Replied by nuno.n on topic How to remove menu tabs from Kunena Template
I've just upgraded to Kunena 2.0.4.
The menu tabs had been removed in my previous version, now they're back!... :S
How do I remove them? I just want a simple menu integrated in my site's top menu and I completely forgot how I did that the last time!
Thanks in advance!
Thanks in advance!
13 years 8 months ago #139910
Replied by sozzled on topic Edit, hide, disable or translate menu items in Kunena (e.g. rules, help, search)
*** Topics merged ***
13 years 8 months ago #139990
by uzbaby
Replied by uzbaby on topic Kunena default language files
Hello dear developers. I want temprorary translate en-GB files to my language and use them as en_GB. I find all files in ./administrator/components/com_kunena/language and
./components/com_kunena/language.
But my forum still has many english words. For example main user manu. Where can I find all kunena front-end files?
I already making translation via transifex but I have no mylang-mylang folder in my root. So I need to translate en-GB (default)files to my language temprorary.
thank you so much in advance.
13 years 8 months ago #140015
Replied by sozzled on topic Kunena default language files
13 years 8 months ago #140052
by uzbaby
I understand about main menu but what about profile texts...there are so many words still in engllish.
13 years 8 months ago - 13 years 8 months ago #140053
This topic will answer your questions about how to translate the menu items (like Recent Topics, Index, Search, Rules, Help, etc.)
To translate other text you will need to install a language pack for your Kunena. Download the language pack from the download page which also tells you how to install the language pack for your language.
Last edit: 13 years 8 months ago by sozzled.
Time to create page: 0.212 seconds
