Merged Shape 5 CSS and JS Compressor cannot be used with Kunena
14 years 1 month ago - 14 years 1 month ago #134030 by xpatman
I hope this in the right place
The template looks a real mess with a large gap next to the posters and the edge when the recent topics is chosen, any ideas.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 30M
Joomla default template details : yoububble | author: Youjoomla LLC | version: 1.0 | creationdate: 02-18-2012
Third-party components: AlphaUserPoints 1.7.4 | CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: None
Modules: Kunena Latest 2.0.2 | Kunena Stats 2.0.2 | Kunena Search 2.0.2
Last edit: 14 years 1 month ago by xpatman.
14 years 1 month ago #134033 by sozzled
This is clearly a case of My Joomla site template makes a mess of Kunena . You need to discuss this issue with the person/people where you obtained your Joomla site template.
14 years 1 month ago #134078 by emgame74
We have changed template provider from Rockettheme to Shape5.
Now it seems the Kunena Forum will not function.
As super user and the site offline, we get following message already at the front page with css/js compression activated:
Fatal error: Cannot redeclare class aCssRulesetStartToken in /var/www/vhosts/escnorge.net/httpdocs/administrator/components/com_kunena/libraries/external/cssmin/cssmin.php on line 69
The "last comment" module is installed at frontpage.
Not allowed? You're welcome!
14 years 1 month ago - 14 years 1 month ago #134084 by sozzled
I am not sure if I properly understand what you mean by "with CSS/JS compression activated". How do you do this (or what facility are you using that does this)? What happens if you deactivate this "setting"?
We know that not all Joomla templates work with Kunena - see My Joomla site template makes a mess of Kunena - but it's also not the Kunena Project team's responsibility to fix these problems either. In the first instance I would suggest that you go to Shape5 and ask them what they know about your template and K 2.0.
Last edit: 14 years 1 month ago by sozzled.
14 years 1 month ago #134093 by xpatman
It is the kunena Blue Eagle 2.0
Just to let you know that is was a conflict with 'Shape 5 CSS and JS Compressor" plug in which now has been turned off.
Cheers
14 years 1 month ago #134096 by kiwi3685
Xpatman, I think you misunderstood sozzled's comment. He said "... where you obtained your Joomla site template."
Kunena Blue Eagle 2.0 is NOT a Joomla template.
Joomla templates, and other modules often contaminate Kunena displays. Gad you found your problem, though I'm sure it would have been possible to love it without completely removing those plugins.
Time to create page: 0.156 seconds
