Question Attachments not uploading
14 years 1 month ago #133912 by dougmcneill
Every time I try to upload an attachment to my newly-configured forum, I get the follwoing message:
Notice •Failed to upload file '': File was not uploaded.
Message •Your message has been successfully posted
Not really sure what's mis-configured here, so any assistance would be greatly appreciated. I've been poking around in my settings all day without any luck.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : js_wright | author: Joomlashack | version: 3.0.8 | creationdate: August 2012
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: None
14 years 1 month ago - 14 years 1 month ago #133917 by sozzled
Replied by sozzled on topic Attachments not uploading
G'day, Doug, and welcome to Kunena.
We get this question a lot; there are many topics in the forum that relate to this issue.
In your case, the first thing that I would do is decide whether you want Community Builder or Joomla to control access. You have set the "access" option to "yes" for both CB and Joomla; choose one or the other.
There are many reasons why people cannot upload attachments. It could be a permissions issue, a file size issue, attachment format issue or something else.
What is the format of the file that you want to attach? Your configuration settings show that you can attach files of the following types: txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2
Do you allow these file type to be uploaded in your Global Configuration settings?
Last edit: 14 years 1 month ago by sozzled.
The following user(s) said Thank You: dougmcneill
14 years 1 month ago #133974 by dougmcneill
Thanks for the reply, Sozzled.
sozzled wrote: In your case, the first thing that I would do is decide whether you want Community Builder or Joomla to control access. You have set the "access" option to "yes" for both CB and Joomla; choose one or the other.
Sorry - I'm still a bit new to Joomla, Community Builder, and Kunena, so I'm not all that familiar with the settings, and I'm not seeing anything in my configuration options that resemble an "access=yes" setting, as you mention above - any chance you could direct me to the specific setting you're referring to? I certainly realize that neither of these products are Kunena or yours to support, but I'd sure appreciate a quick nudge in the right direction.
sozzled wrote: What is the format of the file that you want to attach? Your configuration settings show that you can attach files of the following types: txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2
I tried uploading an image (.png format) and a .txt file in my testing.
sozzled wrote: Do you allow these file type to be uploaded in your Global Configuration settings?
Are you referring to the Joomla global configuration settings? Where is this setting found within that menu? I'm also not seeing a similar option.
14 years 1 month ago - 14 years 1 month ago #133994 by sozzled
These are your Kunena integration settings (extracted from your configuration report earlier):
I have highlighted in different colours the three areas that seem (to me) to conflict.
When I referred to Global Configuration settings, yes, I meant the Joomla Global Configuration settings.
As I mentioned in my previous posting, there are many reasons why images or other attachments fail to upload. Have you looked in the other reasons (e.g. folder/file permissions, the size of the file you wish to upload or the physical dimensions of the image you want to upload)?
14 years 1 month ago #134255 by dougmcneill
Plugins: None
Well, I left Joomla access on and turned CommunityBuilder access off. My file permissions *appear* to be correct, unless there are some kunena-specific permissions I'm unaware of/haven't found (I can upload files from the administrative backend, for instance). Max post size is 8M, and max uploadable file size is 10M for the site. The images I was attempting to upload were well within the defined limits (and I pushed them out, just to be sure), and the txt file I tried was also tiny...still getting the same result.
Any other suggestions?
14 years 1 month ago #134257 by sozzled
The reasons why attachments do not upload (and there are dozens of them) are:
  • Something in your PHP .ini file prevents uploads
  • Somehow there's a Javascript library conflict that prevents the open/save dialog from appearing
  • You do not allow certain MIME types in Joomla/Kunena
  • The files you're trying to upload are too big
  • Your Ubuntu webserver folder permissions are wrong
  • You have ACL conflicts
  • The person trying to upload a file has not logged-in to your site
  • You have an issue with your Joomla menu
  • Badly/wrongly installed Kunena.
Those are the common reasons. Sometimes your hosted environment just won't plain work and that's when you should look at the When all else fails, try this approach. If Kunena does not work, straight away (literally "out of the box") then I would not waste too much more time. I would try things on a differently hosted environment, just to make sure.
One in every 1000 websites have these kinds of issues. Most of the time it's because people have changed something.
The first place I would look is your folder/file permissions. If you have all folders set with the same permissions (and all files in all folders set with the same permissions as one another) according to the Joomla recommended guidelines, then this would be a good starting point. See Securing Kunena
The following user(s) said Thank You: pequeno74
Time to create page: 0.170 seconds
