configuration report
Merged How to create category and sub-category icons in K 2.0
14 years 2 weeks ago #133332
by polhallen
How to create category and sub-category icons in K 2.0 was created by polhallen
Hi folks!
I'd like personalize kunena inserting a different image to category and sub-category.
I read an howto but only to change an image category.
Can you help me?
thanks!
Can you help me?
thanks!
14 years 2 weeks ago - 14 years 2 weeks ago #133350
by TKtemp
Replied by TKtemp on topic How to create category and sub-category icons in K 2.0
You need to create 2 gif images for any category and place them in folder
/JOOMLA root / media / kunena / category_images/
with and height of images should be 32px x 32px
Names of images must be:
where 66 is category ID.
66_on.gif will display when new posts are present in this category
66_off.gif will display in all other case.
for other category with ID 128
names of images should be
etc...
For subcategories names of images are:
Hope this helps.
etc...
Hope this helps.
Last edit: 14 years 2 weeks ago by TKtemp.
The following user(s) said Thank You: manuela
14 years 2 weeks ago #133370
Replied by sozzled on topic How to create category and sub-category icons in K 2.0
TKtemp is right. The procedure in K 2.0 is the same as
the procedure used in K 1.7
The procedure is documented in Category icons in the Wiki.
14 years 4 days ago #134123
by san65
Replied by san65 on topic Making Use Of Category Image Path: How To
I would like to be able to use the facility of category image path. I created a folder "kunena/category_images" as described in the tool-tip for Kunena configuration, and populated it with the appropriate images. Now do I now link individual images in the folder with the corresponding category?
Any help on this would be appreciated.
Thanks in advance.
Thanks in advance.
14 years 4 days ago #134124
by TKtemp
Replied by TKtemp on topic Making Use Of Category Image Path: How To
you do not need to create any folder, it is created automatically on installation of Kunena.
Read Here how to use it
www.kunena.org/forum/K-2-0-General-Quest...cons-in-k-2-0#133350
14 years 4 days ago #134132
*** Topics merged ***
Time to create page: 0.216 seconds
