Merged How to create category and sub-category icons in K 2.0
I'd like personalize kunena inserting a different image to category and sub-category.
I read an howto but only to change an image category.
Can you help me?
thanks!
/JOOMLA root / media / kunena / category_images/
with and height of images should be 32px x 32px
Names of images must be:
where 66 is category ID.
66_on.gif will display when new posts are present in this category
66_off.gif will display in all other case.
for other category with ID 128
names of images should be
etc...
For subcategories names of images are:
Hope this helps.
The procedure is documented in Category icons in the Wiki.
I would like to be able to use the facility of category image path. I created a folder "kunena/category_images" as described in the tool-tip for Kunena configuration, and populated it with the appropriate images. Now do I now link individual images in the folder with the corresponding category?
Any help on this would be appreciated.
Thanks in advance.
you do not need to create any folder, it is created automatically on installation of Kunena.
Read Here how to use it
www.kunena.org/forum/K-2-0-General-Quest...cons-in-k-2-0#133350
