Question Closed groups / small forums?
14 years 2 months ago - 14 years 2 months ago #133135 by hansv
Hello all!
I'm new to Kunena and playing around with it.
But I do have a question, and I don't know if it is posible...
I want to set up a kind of community. Each of the users has to register and choose a group/forum to belong to.
A user has to be able to post messages in the chosen forum. Only to the users of that forum.
In the end the site will end up with +- 20 groups, each counting +-50 members.
Is this possible, or do I have to create 20 different kunena forums?
Last edit: 14 years 2 months ago by hansv.
14 years 2 months ago #133161 by sozzled
Yes it's possible. Set up a category for each user and, if you like, assign that user to be a moderator within that category.
14 years 2 months ago #133340 by hansv
Replied by hansv on topic Closed groups / small forums?
Ok, categories. But a user has to be able to chose a category by himself (only 1!).
And that is something I can't find in the configuration?
Example;
During the registration (where you have to give your name, username,....) they should be able to chose a certain categorie.
And they only should be able to post messages visible for that categorie.
Thx!
14 years 2 months ago #133342 by cbrace
I think an administrator will need to assign new users to the specific group(s) you've created in the Joomla ACL and associated with the various subforums in Kunena.
14 years 2 months ago #133343 by hansv
ok thx.
I will have to look to another solution than.
I really need user to self register to a certain group (and only that group).
14 years 2 months ago #133362 by sozzled
Users cannot "assign themselves" to a specific forum category that is protected by ACL security. Until such time as Joomla implements a registratuon system that allows, at registration time, which a selection of choice for the new member then I think your wish is a far-off fantasy. Using a very simple analogy, it's a bit like saying - at the time of registration - "Select from the following categories: ordinary user, author, editor, publisher, manager, administrator, superadministrator." Well, Joomla doesn't give new members this choice and we are not aware of any other forum product that accommodates this requirement.
From what you said, if you only have a small forum in the first place and if people can wait a little bit of time from when they register until when you can assign them the necessary moderation and/or ACL adjustments, I would not imagine your "problem" to be a deal-breaker.
