Question Kunena module positions
14 years 2 months ago #132953 by kiwi3685
Just a couple of general questions about using module positions.
  1. I note the wiki says that kunena_topic_n " puts an add after (n)umbers of topics in a section" It appears that is literally correct, whereas I had assumed (hoped?) it would really mean "puts an add after EACH (n)umbers of topics in a section" Is this correct, or is there a way to get the module to repeat after every (n) topics? (Same question applies to kunena_msg_n).
  2. I would like the same banner to appear in the topic lists AND the message lists (i.e. both kunena_topic_n and kunena_msg_n). Is there any way to achieve this other than by having two copies of the same banner?
The following user(s) said Thank You: b00ker
13 years 10 months ago - 13 years 10 months ago #139228 by b00ker
Replied by b00ker on topic Kunena module positions
kiwi3685 wrote: Just a couple of general questions about using module positions.
thats important question!
Last edit: 13 years 10 months ago by b00ker.
13 years 10 months ago #139229 by sozzled
Replied by sozzled on topic Kunena module positions
G'day, b00ker, and welcome to Kunena.
Banner ads, themselves, are not specifically issues relating to Kunena but are more related to methods used to display them in Joomla. Most banner ads are displayed with a Joomla "banner ad display" module. As you probably know, you can assign a module to be displayed in a specific module position. If you want to display the module in several different module positions, you need to create several instances of that module.
You do not need several instances of the advertisement image. You need several instances of the module that is used to display the same image in more than one module position on your Joomla website.
