Question Delete a post
14 years 2 months ago #132080 by fribse
Delete a post was created by fribse
I'm the administrator of the forum, and Kunena marks me as such.
I've marked a post in a topic for deletion, and it's greyed out.
But where do I go from there?
I've tried pruning the post, but no such luck.
The page looks like this:
As you can see it shows the post marked for deletion with grey, but I don't see any button that says 'yes really delete'.
The config looks like this:
htaccess: Exists | PHP environment: Max execution time: 600 seconds | Max execution memory: 128M | Max file upload: 50M
Joomla default template details : dkdb | author: Dykkerklubben Dannebroge | version: 2.5.1 | creationdate: 2012-08-22
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.8
Plugins: None
Modules: Kunena Stats 2.0.1
Best regards
Fribse
Dykkerklubben Dannebroge www.dkdb.dk
We're a volunteer driven diving club in Mosede, Denmark.
Har du brug for en dykkerklub der rummer alle, så kom ned til os.
14 years 2 months ago #132082 by sozzled
Replied by sozzled on topic Delete a post
I will try to get an answer for you. Usually site administrators can permanently delete messages. It's possible that your user account is not really an administrator or it's possible that you have changed your J! 2.5 ACL settings in some way.
14 years 2 months ago #132083 by fribse
Replied by fribse on topic Delete a post
Do you know which setting in the ACL that handles this?
As I have many roles in our diving club, I'm part of several groups.
The groups all have different ACL's attached, and I'm worried that the K2 does not handle cumulative rights properly.
Best regards
Fribse
14 years 2 months ago #132084 by fribse
Btw. if I log in to the frontend as a superuser, I do see the 'Permantently delete post' button.
Best regards
Fribse
14 years 2 months ago #132085 by sozzled
K2 ... or K 2.0.1? :p
Yes, I have no problem as an administrator or as a "super" adminsitrator at this website.
I don't know which ACL settings are involved. Because I never tamper with ACL settings, I never have had any problems.
14 years 2 months ago #132087 by fribse
he, 2.0.1 of course.
Well I had to modify it with a few extra levels, no tampering there :-)
I've tried adding my user to "admin", but that didn't change anything.
Best regards
Fribse
Time to create page: 0.152 seconds
