Question The Kunena template CSS files are not "human-friendly" - they are too hard too read
I'm very happy with this kunena component for joomla because it works really awesome! But for the CSS files it is a disaster everything is set on 1 single line!????? Is there a way to get it displayed under each other for editting.
This is my reqeust also.
I think there is nothing else to say because it rocks really bad :lol:
Regards,
Patrick
Most of the time, however, it is totally unnecessary to modify any of the original Kunena template CSS files. In fact, if you modify any Kunena files then you have to modify them again every time you upgrade Kunena. This is why I continually recommend that, for simple CSS style changes, people should read How do I change the colours of my template in Kunena?
sozzled wrote: Most of the time, however, it is totally unnecessary to modify any of the original Kunena template CSS files. In fact, if you modify any Kunena files then you have to modify them again every time you upgrade Kunena. This is why I continually recommend that, for simple CSS style changes, people should read How do I change the colours of my template in Kunena?
I'm awere of that i loss all of my modifications. But i edited core files etc etc. So i will not update any time soon with that particular website/forum!
Thanks for all your help.
Regards,
Patick
As long as you are aware that you have painted yourself into a corner that you will have trouble getting yourself out of, you should should also understand that every new version of Kunena contains dozens of fixes that you will never be able to use because you cannot upgrade. This is the whole reason why we strongly advise people to never modify the original Kunena core software; this is the whole reason why we strongly advise people to make their own customised changes away from the areas where Kunena replaces files as part of component software upgrades. Good luck.Patrick91 wrote: I'm aware of that I [will lose] of my modifications. But I edited core files etc etc. So i will not update any time soon with that particular website/forum!
