Question Font colour defined by forum rank
14 years 3 months ago #131876 by spoleto999
Rank Color was created by spoleto999
Hi, is there a way for every special rank to have a default color in their post?
For ex an admin post:
texttexttexttexttexttexttexttexttext
a mod post
If not, ho can i change the default colors avaiable to have a custom one?
And i found a bug too: if I set a color tag in a List, I have to open it on every line or it won't be used.
14 years 3 months ago #131895 by sozzled
Let me state at the outset, forum ranks in Kunena convey no special privileges or differences in operation from one "rank" to another. The only things that forum ranks tell us is how more or less experienced is a user within a particular community.
spoleto999 wrote: Hi, is there a way for every special rank to have a default color in their post?
Short answer: no.
spoleto999 wrote: Can I change the default colors available to have a custom one?
I'm not sure what you mean. If you mean, would you like all the text on your forum posts to be in a different colour then the answer is yes. If you mean "can a user be offered a 'default' choice option for font colour?" then the answer is no.
spoleto999 wrote: And i found a bug too: if I set a color tag in a List, I have to open it on every line or it won't be used.
Different question and different subject. Please create a new topic.
14 years 3 months ago #131914 by spoleto999
I mean, can I change the pattern colors to add or modify 2 of them to 2 my favourite colors?
Ex: if I click the button "color" (to add some colorate text in a post), a list of a lot of colored square appears and I can click on one of them; can i change the preset of these colors to add some wierd colors I like?
14 years 3 months ago #131917 by sozzled
spoleto999 wrote: I mean, can I change the pattern colors to add or modify 2 of them to 2 my favourite colors?
I suppose you can do this but don't ask me how it's done. I'm just a user like you; I'm not a developer. This is not a standard feature of Kunena. If you want this done you will need to do build your own "custom colour palette" or engage a professional to develop this for you. Professional software development services are not free. Would you like me to put you in touch with some people I know who do this kind of work?
Time to create page: 0.161 seconds
