Question Forum category not showing up
14 years 3 months ago #131581 by sultra
Why is the forum category that I created does not appear? ". previously I've disable Kunena-Joomla Integration because I wanted the user need not be registered
14 years 3 months ago #131596 by sozzled
Can you ask your question in a more specific way, please? I do not understand what you mean by "forum category does not appear"?
Where does this happen? For whom does this happen? Have you published this category? Have you changed any of the category's permissions?
14 years 3 months ago #131625 by sultra
I mean remove the Login Menu by:
1. Login Back End Joomla
2. Component
3. Kunena Forum
4. Configuration
5. Kunena Plugin -> Kunena Joomla Integration -> Enable = NO
By the way the above login menu does not appear again. New issue that arises is the forum Category at page Front End does not appear after login menu is removed. In addition to all categories at page Back End is already published. How can I make the forum category in the page remains displayed even though the front end menu logy eliminated. Please send me the solution thanks
