Merged attachment problem: "user 0 does not exist"
14 years 3 months ago #130237 by ddqv
We cannot upload attachments in a topic, not as a guest, not even as admin.
Error message (Dutch): "gebruiker 0 bestaat niet" = "user 0 does not exist"
thalassaforum.classy.be/
Configuration:
htaccess: Missing | PHP environment: Max execution time: 60 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : jm-0013 | author: joomla-monster.com | version: 1.7 | creationdate: 10/10/2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Plugins: None
14 years 3 months ago #130245 by sozzled
You have two menu items in mainmenu.
One is named "Forum", the other is named "Thalassa Forum". Delete the second item. Use the first item and make it the default menu item for your site.
The following user(s) said Thank You: ddqv
14 years 3 months ago #130299 by ddqv
Thank you for your quick reaction!
I've done what you suggested - for as far as I understand, but with no effect.
Configuration:
Plugins: None
14 years 3 months ago - 14 years 3 months ago #130306 by sozzled
We could be chasing the wrong problem in respect of the confused menu that you've created (and, if anything, the menu that you now have is worse than what you had before). The truth of the matter is that I don't know what causes "user 0 does not exist" because I cannot find any other topics in this forum that helps.
Unless someone else can give us assistance, the cause of your problem remains unexplained. :unsure:
However, I can tell you is if your Joomla is not well-behaved, you will have problems elsewhere (e.g. in Kunena). The Joomla menu you've created for your site is not what we recommend. I suggest that you trash all menu items that relate to Kunena and rebuild them. The technique for doing this is described in Missing Kunena Menu . This may or may not fix the other problem but, at least, we've eliminated one possible cause.
You could also try resetting all Kunena configuration settings to their original default values.
Last edit: 14 years 3 months ago by sozzled.
14 years 3 months ago - 14 years 3 months ago #130985 by lyrafatima
I have allowed guest users to upload image to my website forum. You will be able to see his post, unfortunately the image does not appears but the image will be uploaded to media/kunena/attachments/0 folder.
These are the complete messages I am getting. Your message has been successfully posted. Cannot save attachment: User 0 doesn't exist!
Your usual help will be highly appreciated.
Last edit: 14 years 3 months ago by lyrafatima.
14 years 3 months ago - 14 years 3 months ago #130986 by lyrafatima
I am having also the same issue but only for guest user. I did tried different test joomla site with default templates and setting still I am having the same issue. When the guest user submit a reply topic it will be posted but without the attachment. Here is the complete message I am getting.
I am pretty much sure of the settings in upload and security to allow everybody same as the category folder. Maybe I missed something. Please help.
"Your message has been successfully posted. Cannot save attachment: User 0 doesn't exist!"
I forgot to inform you guys I am using Kunena 2.01 and Joomla 2.5.6
Time to create page: 0.174 seconds
