Question How to hide userlist?
- tommytoxen
- Junior Member
All I'd like to do is hide the link to the userlist at the bottom please?
I've tried adding to my CSS
#Kunena .kuserlist {
display: none;
But the userlist link is still there, help please?
- Jiminimonka
- Elite Member
- YBAS!
If you look in the Kunena Configuration Page - there is a setting "Show Who is Online", change that.
I renamed the topic so it is more useful to others.
- tommytoxen
- Junior Member
Thanks for the reply.. but don't quite understand, surely disabling 'show who is online' would simply hide who is online, and not hide 'Userlist' link?
- Jiminimonka
- Elite Member
- YBAS!
You can disable displaying the userlist for users of your forum who are not logged in.
You can modify the PHP source code to remove the part that creates the link (I don't know, exactly, which file you need to change). Whatever changes you make to the PHP source code - to remove this link - unless you create your own Kunena template, you would need to reapply those changes again, every time you upgrade Kunena.
Actually you can, though I admit some old / IE browsers may ignore it:sozzled wrote: You cannot hide the link to the userlist on the <em>Kunena</em> template by using CSS because there's no named element that you can hang a "display: none;" rule on.
#Kunena ul#kstatslistright li:nth-of-type(3){display:none;}
(added to template.css in my joomla template, of course)
I also prefer not to display the list to anyone, but do want to use the stats info. So this was the only and easiest solution. It works well.
