Question How to hide userlist?
14 years 3 months ago - 14 years 3 months ago #129912 by tommytoxen
Yes I've searched :P for 3 hours now, actually, but all I can find is old posts referring to 1.6 where none of those files even exist anymore to edit.
All I'd like to do is hide the link to the userlist at the bottom please?
I've tried adding to my CSS
#Kunena .kuserlist {
display: none;
But the userlist link is still there, help please?
Last edit: 14 years 3 months ago by Jiminimonka.
14 years 3 months ago - 14 years 3 months ago #129926 by Jiminimonka
Replied by Jiminimonka on topic How to hide userlist?
Hi tommytoxen,
If you look in the Kunena Configuration Page - there is a setting "Show Who is Online", change that.
I renamed the topic so it is more useful to others.
Please read the FAQ.
Only one question per topic.
14 years 3 months ago #130002 by tommytoxen
Replied by tommytoxen on topic How to hide userlist?
Hi Jim,
Thanks for the reply.. but don't quite understand, surely disabling 'show who is online' would simply hide who is online, and not hide 'Userlist' link?
14 years 3 months ago #130021 by Jiminimonka
My mistake. You can hide the userlist from guests in the Kunena Security section. I will ask the devs if there is a way to hide it from everyone.
14 years 3 months ago #130074 by sozzled
Replied by sozzled on topic How to hide userlist?
You cannot hide the link to the userlist on the Kunena template by using CSS because there's no named element that you can hang a "display: none;" rule on.
You can disable displaying the userlist for users of your forum who are not logged in.
You can modify the PHP source code to remove the part that creates the link (I don't know, exactly, which file you need to change). Whatever changes you make to the PHP source code - to remove this link - unless you create your own Kunena template, you would need to reapply those changes again, every time you upgrade Kunena.
14 years 3 months ago #131736 by kiwi3685
Replied by kiwi3685 on topic How to hide userlist?
sozzled wrote: You cannot hide the link to the userlist on the <em>Kunena</em> template by using CSS because there's no named element that you can hang a "display: none;" rule on.
Actually you can, though I admit some old / IE browsers may ignore it:
#Kunena ul#kstatslistright li:nth-of-type(3){display:none;}
(added to template.css in my joomla template, of course)
I also prefer not to display the list to anyone, but do want to use the stats info. So this was the only and easiest solution. It works well.
The following user(s) said Thank You: Patrick91
