Question Kunena is not seen in some browsers
14 years 3 months ago #129577 by neon26
Hi I have problem with 2.0.1 kunena
Some users of my website tell me not to see the forums with firefox and chrome and that solving this problem have had to put Internet Explorer and give the option compatibility view and the small text box that puts out the address www. josportal.com
What can be done to fix this?
I see my site and forum with chrome firefox without problems but I did not sample.
What could be?
14 years 3 months ago #129578 by sozzled
Perhaps this is an issue with your template? Your configuration report may assist us. Also, please read My Joomla site template makes a mess of Kunena .
14 years 3 months ago #129579 by neon26
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 96M | Max file upload: 8M
Joomla default template details : rt_radiance | author: RocketTheme, LLC | version: 1.2 | creationdate: December 12, 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: CommunityBuilder 1.8.1 | UddeIM 2.7
Plugins: Search - Kunena Search 1.7.2
Modules: Kunena Latest 2.0.1 | Kunena Search 2.0.1
14 years 3 months ago - 14 years 3 months ago #129582 by sozzled
If you require the Kunena Search plugin, please upgrade to the one that it compatible with K 2.0.1. If you have never used (or do not require) this plugin, then please uninstall it. Does that help?
Your website is currently offline at the moment, too.
Last edit: 14 years 3 months ago by sozzled.
14 years 3 months ago #129589 by gimenezadrian
14 years 3 months ago #129842 by willey
you may be disabled in the settings of your browsers so try to check out your settings
SSL provide the strongest protection, greatest flexibilty
Time to create page: 0.147 seconds
