Question How do we prevent a specific user group level posting in K 2.0?
14 years 4 months ago #129459 by chetanmadaan
Hi -
we recentlly migrated from kunena 1.7.0 to 2.0.1 and had some quick questions that any kunena mod can answer really quickly.
in kunena 1.7.0 there was a folder names funcs in the front /components/com_kunena/
in kunena 2.0.1 that doesn't exist.
in that folder we had the file post.php and the function post() modified in a way so that it was not letting a particular user group level post.
We want to know where the file and the function has been moved to... so that we can work around it.
14 years 4 months ago #129479 by xillibit
Look into /controllers/topic.php
14 years 4 months ago #129511 by sozzled
I would also add that there have been substantial improvements made since K 1.7.0 to govern the access and ability to post/reply to topics based on Joomla ACL without the need to hack the source code. I would suggest that you use the K 2.0 Category Manager to examine the new functionality and apply it to those categories where you wish to restrict your community members' ability to use those categories. I hope that helps.
