Question New Problem - K2.0.1 - bug with anonymous posting
14 years 4 months ago - 14 years 4 months ago #129121 by kross76
When you create a "New Topic", allowing "All Categories", the anonymous option is not shown (for the first category that comes up automatically). If you pull down the list of categories and select a different category, the anonymous option shows up. This is more serious than it looks because when our users want to post a new topic anonymously, and they don't see that option, they will probably elect not to post. Note that if you change the new topic menu to land on a specific category, the anonymous option shows up find, but then you're not allowed to choose a different category.
This problem showed up early on when anonymous was being developed and was fixed. I can't see an easy work-around (but perhaps you can). Hopefully, there's an easy solution.
(note - I edited this post for the Kunena folks as I found some old correspondence pointing to this problem in the past and it's resolution in a prior version).
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : ja_purity_ii | author: JoomlArt.com | version: 1.2 | creationdate: 02/02/10
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.1 | creationdate: 2012-07-07
Third-party components: CommunityBuilder 1.8.1
Plugins: Search - Kunena Search 1.7.2
Last edit: 14 years 4 months ago by kross76. Reason: Found additional information
14 years 4 months ago #129347 by kross76
Not sure I attached file on last post
14 years 4 months ago #129378 by sozzled
Please read Support for PC-hosted websites (e.g. WAMP, XAMPP)
Suggest you update Kunena Search 1.7.2; incompatible with K 2.0.
Suggest you might like to change the menu item name in kunenamenu to "Discussions"
*** Topic moved to another category ***
14 years 4 months ago - 14 years 4 months ago #129381 by kross76
Sozzled,
Thanks for your note, and with 20/20 hindsight, I can understand how stupid it is to ask you to look at an issue on localhost. I'm in the process of simultaneously checking our Kunena 2.0.1 and figuring out my migration path to Joomla 2.5.6. The process is long (at least for 2.5.6), and localhost is easiest to get going.
Anyway, I've uploaded the system to our hosting site. You can access it at temp.ceoexpert.net . Also, note that the anonymous issue only occurs when you're logged in and try to post a new subject. It's not relevant for guest's posts. You can log in using my credentials -
. This is a simple registered user. If you want back end access, I'm happy to give it to you, but in a private email.
I'm re-posting the configuration parameters here:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Plugins: None
Last edit: 14 years 4 months ago by sozzled. Reason: Hide the site login details
14 years 3 months ago #129956 by kross76
I just wanted to see if you've had a chance to look at this? It's not urgent, but I'd like to migrate to 2.0.1 when I can. Thanks.
Time to create page: 0.164 seconds
