Question Downgrade Kunena 2.0.x > 1.7.x
14 years 4 months ago #128549 by marcofink
Hey guys,
I was wondering if there is any documentation or known method to downgrade from Kunena 2.0 to a prior release without completely wrecking a site or losing post data.
I've looked through the wiki and searched through the posts here, but unless I've missed something I can't find any info.
Thanks!
14 years 4 months ago #128551 by sozzled
See Kunena 2.0.1 Read Me (same thing applies to K 2.0.0, too).
There is no "downgrade" option. The only reliable way that you can downgrade is to restore your site from the backup you made before you upgraded to K 2.0.x
14 years 4 months ago #128661 by Matias
Database has changed so much that it's very hard to restore it to what it was in Kunena 1.7. I would rather report the issues and help us to fix those as soon as possible.
14 years 2 weeks ago #136194 by eonila
Hope there is some improvement now...
I mean - Did anyone discovered any safe way to downgrade Kunena?
The problem I'm facing:
- I can't use backup, because there were so many new posts in my forum... I just can't allow to loose it.
- I have no idea how to fix a bug, that after upgrade happened
Authors can see all. Syperadministrator sees all... But operators lost all topics, and threas in the frontend.
Any chance to fix it?
14 years 2 weeks ago - 14 years 2 weeks ago #136198 by Jiminimonka
What Matias stated here above has not changed, and it is not likely too.
Whenever upgrading or making a change to your website you should ALWAYS make a backup first. With Joomla there is the excellent Akeeba Backup which takes out all the complexity of doing this (and restoring it too).
Then, if something goes wrong, you can go back to the earlier version.
Maybe if you provide a URL and your Configuration Report for Kunena, someone might be able to assist with your problem.
Please read What information should I include when I ask for help (including how to post my configuration report)? .
Please read the FAQ.
Only one question per topic.
Last edit: 14 years 2 weeks ago by Jiminimonka.
14 years 2 weeks ago #136223 by sozzled
See Kunena 2.0.2 Read Me .
sozzled wrote: There is no "downgrade" option. The only reliable way that you can downgrade is to restore your site from the backup you made before you upgraded to K 2.0.x
