Question SEF URLS w/o IDs
14 years 4 months ago #127974 by payon
SEF URLS w/o IDs was created by payon
as I understood from older posts, you wanted to make the SEF option more flexible.
Here the opportunity to disable the catid and postid in the SEF URL was discussed.
But I cannot find the option in the backend :(
Will this be updated or is there any other customized solution (by re-writing the router.php)?
Thanks a lot!
payon
14 years 4 months ago #128645 by Matias
Replied by Matias on topic SEF URLS w/o IDs
Yes, it has already been implemented. But existing categories will keep the original URLs as we assume that most admins do not want to change those.
In the backend go to category manager and select each category. In there you can see a new field which contains category alias and underneath a list of existing aliases. You can change the current one and unselect those you don't want to keep (just remember that Google still uses those, so I'd keep them).
