Question How to edit a topic?
14 years 4 months ago #127295 by jenfar
How to edit a topic? was created by jenfar
Hi I'm a newby to Kunena and I've just installed "com_kunena_v2.0.0_2012-06-27" with Joomla 2.5.6. The installation of Kunena seemed fine. I've fixed one error with the kunena.file.class.1.6 and so far so good. However I want to now eithier delete or edit the default topic of 'Welcome to Kunena!' but can't seem to find anywhere in the backend of the Kunena control panel to do it? Is this a bug or am I meant to register and log-in to the front end of the forum to achieve this?
14 years 4 months ago - 14 years 4 months ago #127297 by Mortti
Replied by Mortti on topic How to edit a topic?
You can edit or delete them directly from frontend... in backend you can't do that.
In backend you can remove whole sections or categorys... and trashed topics/messages... if you want remove those what sample data made...(Category Manager)
Last edit: 14 years 4 months ago by Mortti.
The following user(s) said Thank You: jenfar
