Merged Topic count not working
14 years 4 months ago - 14 years 4 months ago #127079 by baileyd12345
THIS CAN BE DELETED - I FOUND THE RECOUNT STATISTIC TAB!!!!!!
Sorry
Hi Folks, not sure if I've done something wrong when upgrading.
Basically the topic and reply counts are all now showing as zero.
The actual topics and replies have migrated fine so the content is all still there.
Does anyone know how to fix this?
David
Last edit: 14 years 4 months ago by baileyd12345.
14 years 4 months ago #128714 by twilliams81
Please see the attached image so that you can see what I am referring to.
Also, here is my configuration report
htaccess: Missing | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 2000M
Joomla default template details : rt_entropy_j16 | author: RocketTheme, LLC | version: 1.6.3 | creationdate: November 11, 2011
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.0 | creationdate: 2012-06-27
Kunena version detailled: Kunena 2.0.0 | 2012-06-27 [ Diplomatia ]
| Kunena detailled configuration:
| Joomla! detailled language files installed:
Third-party components: Jomsocial 2.4.1
Plugins: None
14 years 4 months ago #128774 by Matias
How did you manage to install Kunena 2.0 into Joomla 1.7.3? It should not be possible. :)
First I would upgrade Joomla to 2.5.6, Kunena to 2.0.1 and JomSocial to the latest version. Then I would find out if your template has a new version of it.
After that I would recount all categories and see if the problem persists.
14 years 3 months ago #130995 by twilliams81
I'm not sure how or why the system let me upgrade to those versions but it did and the upgrade actually went smoothly. Upgrading Joomla and Kunena together ended up fixing the issue. Thanks!
14 years 3 months ago #131303 by browny
Replied by browny on topic Topic Count not working
Hi, I am very new to both Joomla and Kunena forums, so please forgive me if I'm doing something stupid. I have gone through both joomla and kunena settings and cannot get the count on the topics on the index page to work. If a superuser adds a topic, the topic is counted, but if a normal registered user posts a topic, the topic count does not update. The replies update for all users. Any help and advice gratefully received.
I would post my configuration file, but not sure how to do it even after reading instructions :unsure:
14 years 2 months ago #133792 by san65
For one particular category, the topic count continues to show zero, though there are 3 topics that have been published in that category. Is there some setting that I may have overlooked which may be causing this? For all other categories, the topic number appears to be correctly updating.
Any tips on why this may be happening and the solution would be greatly appreciated.
Thanks in advance.
