Question Migrate 1.7 to 2.0
14 years 4 months ago #126742 by Helfgott
Migrate 1.7 to 2.0 was created by Helfgott
Hi folks, i want to use K 2.0 in my website, but i'd like to ask some questions to do it:
- Actually i have Kunena 1.7.2, there's a guide or "wiki" to update it correctly?
- I've installed Extensions as "Kunena Discuss Plug-in" it will still working after update?
best regards!
14 years 4 months ago #126744 by xillibit
Replied by xillibit on topic Migrate 1.7 to 2.0
There is the upgrade guide : docs.kunena.org/index.php/Kunena_2.0_Upgrade_Guide
You need to use the Kunena Discuss Plug-in in version 2.0, the version 1.7.2 won't work with Kunena 2.0
14 years 4 months ago - 14 years 4 months ago #126745 by Helfgott
Replied by Helfgott on topic Migrate 1.7 to 2.0
Ok, seems quite simple to backup de db and update, but i don't see download for Discuss plugin 2.0, just for 1.7, would you give me a link for it?
Thanks!
Last edit: 14 years 4 months ago by Helfgott.
14 years 4 months ago #126752 by sozzled
Replied by sozzled on topic Migrate 1.7 to 2.0
Helfgott wrote: Ok, seems quite simple to backup de db and update, but i don't see download for Discuss plugin 2.0, just for 1.7, would you give me a link for it?
Thanks!
K 2.0 (and the associated add-on software for K 2.0) is not officially released yet. That is why there is no link for it.
