Question K 2.0 + J! 1.5: SEO patch needed, please
13 years 5 months ago #145721 by neujensl
You should check what components , plugins ,... are installed and if a 2.5 version is avalaible. If not you have to find alternatives .Best to make a backup and try the upgrades on local pc first ofcourse .
Virtuamart is for sure compatible with jZ.5 so should not give much problems ...
At the end you will have to upgrade if you like to add new stuff or you get a problem ...
I think the sooner the better !
The topic has been locked.
13 years 5 months ago #145727 by giuliosensi
Yes... I got almost convinced to upgrade... I will start thinking of it !!!!!
Thanx to all for your support !!
13 years 5 months ago #145732 by sozzled
*** Topic closed by moderator ***
