Solved Attached images not displayed when using message preview
I am currently using Joomla 2.5.9 and Kuena 2.0.4.
On the Forums, I see that I am able to add a File and insert it, I am actually adding an image (JPG and it is within the size limit of what I have set on the configuration).
Howwever when I preview or post it, I can find the image in the post.
Can you please advise?
Cheers
Kris
can-you put please put an image here to dscribe your issue ?
Is this what you were asking?
We assume that you mean that you can not find the image in the post, yes?When I preview or post [an image] I can find the image in the post.
The other part of the question - why images cannot be found after you have posted a message that you attached an image to - that's a bit more difficult to answer. Are you sure you attached the image?
thanks for your replies.
The preview does not show the image, but if I click on submit the image is actually posted correctly.
p.s: I actually saw that working when I started taking screenshots to send in this post.
Cheers and thanks for your time
Kris
