Solved Quoting on forum
- Dragon41673
- Junior Member
(configuration file removed)
- Dragon41673
- Junior Member
Now you should see that buttons, one of them should be "FLAT".
Click it and check if that solve problem.
If so, you can turn to "No" this kunena configuration
BTW: You should update your Kunena Extensions (Kunena Login, Kunena Discuss and Kunena Template) to latest version
EDIT: Search also kunena configuration option "Default topic layout" and set it to "Flat" and Save
- Dragon41673
- Junior Member
Should/can I delete my configuration post so it's not lurking out here?
Dragon41673 wrote: Awesome thank you! That fixed it!
Well, you can do whatever you want with it
