Solved Disable option for users to choose editor...
13 years 7 months ago - 13 years 7 months ago #142282 by QuakeLive
Hi :) ,
is it possible and how to disable option for users to choose which editor they will use. When they go Edit profile, they have an option to choose editor - and I would like to remove that option and only default Kunena editor can be used.
Thanks in advance!
Last edit: 13 years 7 months ago by QuakeLive.
13 years 7 months ago #142310 by xillibit
Kunena has only bbcode toolbar and has nothing else, can-you make a screenshot to see exactly the option ?
13 years 7 months ago - 13 years 7 months ago #142329 by QuakeLive
xillibit wrote: Hello,
13 years 7 months ago #142334 by xillibit
This is for configure the Joomla! editor used to write Joomla! articles and it's has any effects on Kunena. You have the settings if you look in your Joomla! profile.
The following user(s) said Thank You: QuakeLive
13 years 7 months ago - 13 years 7 months ago #142345 by QuakeLive
xillibit wrote: Hi,
Thanks! Hmmm... But, then why there is that option in Kunena if there is no effects on Kunena? Sorry, but I'm a little confused :S :)
13 years 7 months ago #142353 by xillibit
I don't know if we can remove displaying the drop-down for editor...
