Solved administrator css not loading
13 years 7 months ago #142102 by newty
Ive been using kunena for joomla a few weeks and I could have sworn it was working fine.
Today I go into the admin interface and it cannot load the administrator css for joomla (bluestork) template.
It appears that kunena is looking inside the normal front end /templates/ folder, rather than the /administrator/templates/ folder.
On the top bar of joomla, also there is an /administrator/ folder missing, so all the links just take me to the home page of my site.
Just wondering if someone could point out which file I have to look in, to find out the path where the joomla administration template is being pulled from?
Cheers
n
13 years 7 months ago - 13 years 7 months ago #142130 by xillibit
What exact Kunena and Joomla! versions are-you using ?
Last edit: 13 years 7 months ago by xillibit.
13 years 7 months ago #142184 by newty
Replied by newty on topic administrator css not loading
Im using joomla 2.5.9 and kunena 2.0.4
I have replaced all files with the stock ones, just in case there was a corrupted file causing the problem. However, the problem still remains.
There is something causing the path not to load correctly and Im not too sure what it is. Must be another compopnent/module causing it.
Would be grateful for some help in diagnosing.
Cheers
13 years 7 months ago #142185 by newty
I found the problem, it was in document.php inside /libraries/joomla/document/
Extremely weird, there must have been a corruption or something!
Cheers
