Solved
Why do "animated" GIF images not animate on my forum?
Hello. If i upload a gif image on post, this image have no movement (static as jpeg),however if i put a link image gif, of external host, then this gif have movement. why?
thanks.
.GIF images lose their ability to be animated if they are resized dynamically/on-the-fly. If the image is a physically large image, and it is resized smaller then it will no longer animate.
For example if you posted a small image (like the "pointing hand" image in my signature below) then this will not be resized. But if the image is, say, 1000 px x 1000 px, then it will not fit in your forum and it will be resized. If the image is resized, and it was an animated .GIF image, then it will appear on your site as a static/non-animated image.
Thanks, I undestand it. but it is odd that image gif to uploading is only 300x170 (there isnt resize), and this image, post by link, that is the same size, if has movement. It is a small image. Anyway is a minor problem. Best regards.
