Solved Problem upgrading Kunena 1.7.2 to 2.0.4
13 years 8 months ago #141464 by MaxTorS
Hello, I decided to upgrade my forum from 1.7.2 to 2.0.4 version, and I found the following problems:
No recent messages are posted in the latests module, statistics module not properly given, since it says that the most viewed post has 89 views, there are posts with 200k +.
Also when I enter Recent Discussions in the forum menu itself, not the last posts are created.
Report:
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : sienna | author: Shape5.com | version: 1.0 | creationdate: December 2011
Third-party components: Jomsocial 2.8.3
Plugins: Search - Kunena Search 2.0.4 | Content - Kunena Discuss 2.0.4 | JomSocial - My Kunena Forum Menu 2.0.4 | JomSocial - My Kunena Forum Posts 2.0.4 | JomSocial - Kunena Groups 2.0.4
Modules: Kunena Latest 2.0.4 | Kunena Stats 2.0.4 | Kunena Login 2.0.4 | Kunena Search 2.0.4
13 years 8 months ago #141482 by xillibit
Do you have changed settings in Kunena configuration panel ?
13 years 8 months ago - 13 years 8 months ago #141484 by MaxTorS
What configuration need to change? i do not change anything, only upgrade, and module lastest and stats are bugged.
PD: ur signed URL of Become a Kunena Fan is broken " community.joomla.org/groups/viewgroup/61-Kunena.html "
Last edit: 13 years 8 months ago by MaxTorS.
13 years 5 months ago #144563 by momomo
Found any solution to this?
We are also experiencing the same in our Kunena Forum Statistics since we updated from 1.7 to 2.0.4 the data being displayed in the Kunena Forum Statistics is only from the day we upgraded it to 2.0.4 (23 May 2013 - present) not from since we started using Kunena Forum.
13 years 5 months ago #144564 by skybax
in Kunena Cpanel under Tools you have Recount Statistics, see if this helps
The following user(s) said Thank You: momomo
13 years 5 months ago #144566 by momomo
Hi skybax,
Thanks a lot. This solved our problem. :)
Cheers!
momomo
Time to create page: 0.152 seconds
