Solved Some issues with the polls feature
13 years 8 months ago #141355 by gixty
1.- I need to increase the text length of polls options
2.- Polls bars are not beign scaled correctly. They all have the same size eventhough each poll option has a different number of votes.
Please help, thanks.
13 years 8 months ago #141386 by TKtemp
1. Require a hack of kunena core files
2. This issue could be caused by your joomla/kunena template and require link to your site and test user account to login and vote on your site
13 years 8 months ago #141404 by gixty
thanks, could you please tell me what files i need to hack?
13 years 8 months ago #141409 by TKtemp
administrator / components / com_kunena / media / kunena / js / poll.js
at line 22
maxlength:'25',
and
components / com_kunena / template / blue_eagle / html / topic / edit_editor.php
line 115
echo '<div class="polloption">Option '.$x.' <input type="text" maxlength = "25" id="field_option'.$x.'" name="polloptionsID['.$option->id.']" value="'.$option->text.'" onmouseover="javascript:document.id(\'helpbox\').set(\'value\', \''.KunenaHtmlParser::JSText('COM_KUNENA_EDITOR_HELPLINE_OPTION').'\')" /></div>';
13 years 8 months ago - 13 years 8 months ago #141461 by cycleout
Can't find polls feature.
Problem solved - may not have had Polls enabled under Extra.
Last edit: 13 years 8 months ago by cycleout. Reason: Problem solved
