Solved K 2.0.4: Topic and Reply Counter not working
13 years 9 months ago #140132 by Mattj500
I was part way through problem solving an issue regarding my Topic and Reply counter not working on a new forum. My man Sozzled identified I was using an outdated version Kunena(K 2.0.3.) and closed the thread before I had a chance to update and check that the problem was solved. Prior to upgrading my Kunena configuration was displaying that it was up to date so I hadn't checked the website for updates as well. Anyway I am still here as I am still experiencing the issue. New picture attached (3rd one down).
Now updated to K 2.0.4
13 years 9 months ago #140133 by Mattj500
Configuration report:
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 128M | Max file upload: 20M
Joomla default template details : yoo_drive | author: YOOtheme | version: 1.0.0 | creationdate: December 2012
Third-party components: CommunityBuilder 1.9
Plugins: None
13 years 9 months ago - 13 years 9 months ago #140137 by sozzled
I closed the earlier topic for a couple of reasons but mainly because you stated that you had just installed K 2.0.3 on a brand new forum.
Mattj500 wrote: I have a brand new forum.
Is this true? Is it true that you did not have a forum before (perhaps you were using an older version of Kunena)? I have not seen this case reported before when people have a brand new forum. I have, however, seen far too many cases where people had problems upgrading from K 1.x to K 2.0.3 and that's when this issue manifested itself almost identically to the way you have described it. Given the many problems that we had with K 2.0.3, I would not recommend K 2.0.3 to anyone; that's another reason why it's not supported.
To help with this case, I think we need to be clear that we really are discussing s situation where you started with nothing, installed K 2.0.3, and then you had this problem where topics seem to show that there are no replies when, in fact, there are replies.
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago #140159 by rich
Please repair in your main menu (Rib Forum) your wrong menu item.
www.kunena.org/docs/Kunena_menu_issues
Afterwards go in "Backend > Kunena > Forum Tools > Recount Statistics" and recount all statistics.
The following user(s) said Thank You: Mattj500
13 years 9 months ago #140213 by Mattj500
Thank you Rich, the Statistics Recount option worked to update the counter. Is this something one should do from time to time? I wonder why it wasn't counting automatically?
I am unsure what you meant about repairing my menu? I looked at the link you sent and I don't have the problem that it is describing. How did you spot it on my site? Could be the picture I posted, it was cropped down, not showing all of the forum.
@Sozzled Thank you for clarifying. I installed my forum a week or so ago, so not "brand new" I guess. Anyway I am updated now. Any idea why my Kunena installation did not report that it was outdated in the configuration?
Thanks guys
Matt
