Question
Guest posting only possible as "Anonymous"
As the topic states, we are having a problem on our site with guest posting. We enabled guest posting/writing, but when you post as a guest, you cannot give yourself a name and you will appear as "Anonymous", so I am wondering if this is intended or if there is a way to change this.
It is intended because only registered users are give the right to use their chosen names, otherwise we could get impersonations or name conflicts with those that are actual users of a website.
We might eventually make a distinction between display names and account names, but needs to be implemented.
Many sites that have guest posting always default to use "Anonymous"
For your information, K 2.0.3 is not supported by the team. We do not normally respond to topics that relate to unsupported versions of Kunena on the forum. For your benefit, and for the benefit of others reading this topic, people who have "issue" relating to unsupported versions of Kunena should first of all upgrade to K 2.0.4 and then we may be able to help each other better.
Thank you for an interesting question and I am pleased that you received such a prompt answer. This topic can now be considered closed.
