Solved Kunena 2.0.3 - Forum NOT visible to everyone. Why??
13 years 11 months ago #138456 by Sky_80
Hi all !!!
After you upgrade to Kunena 2.0.3
my forum is closed to visitors.
I checked the admin panel ...
This item is on: Forum visible to everyone.
What could be wrong?
Sorry my English.
13 years 11 months ago #138459 by sozzled
Your Kunena configuration report would really help. Thank you. ;)
13 years 11 months ago #138461 by Sky_80
Legacy mode: Disabled | Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 64M | Max file upload: 25M
Joomla default template details : justbusiness-fjt | author: FJT | version: 2.5.0 | creationdate: 16-03-2012
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.3 | creationdate: 2012-11-24
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Third-party components: CommunityBuilder 1.9
Plugins: None
Modules: Kunena Latest 2.0.3 | Kunena Login 2.0.3
13 years 11 months ago - 13 years 11 months ago #138462 by sozzled
You have no published categories in your forum or you have disabled public access to view your categories by settings you have in your category permissions. Check your categories using the Kunena Category Manager.
J! 1.7.5 is not supported. I do not know if K 2.0.3 work with J! 1.7.5; probably not. Best advice is to update to J! 2.5.8 as soon as possible.
As a matter of curiosity, what version of Kunena were you using before you upgraded?
Last edit: 13 years 11 months ago by sozzled.
The following user(s) said Thank You: Sky_80
13 years 11 months ago #138464 by Sky_80
You're number one!
The problem was in the categories.
With the update was set to the voice ... No.
I do not understand.
I had to set Access Level: Public.
Now it all works!
Thanks for helping me!
