Solved [Solved] K 2.0.3 topic icon is not working.
13 years 11 months ago - 13 years 11 months ago #137425 by iLucato
Hi folks, I upgraded to K2.0.3 and noticed that when creating a NEW TOPIC, the TOPIC ICONS aren't showing up.
I have checked the system - legacy and it is deactivated.
Any idea what can be wrong?
Last edit: 13 years 11 months ago by iLucato.
13 years 11 months ago #137429 by sozzled
I do not really know what is wrong in your case. Perhaps you customised your site (or changed some folder permissions) and the new K 2.0 topic icons were not installed when you upgraded (from whatever version you were using before)? Without seeing your configuration report it's too early to say.
Can you show us a picture of what your screen looks like when you press the New Topic "button", please?
13 years 11 months ago #137430 by iLucato
Hi Sozzled,
No permissions were changed.
Where are the new K2.0 topic icons installed? So, I can check if they were installed.
Here is the screenshot:
13 years 11 months ago #137432 by skybax
from what i see all is ok in that screenshot
13 years 11 months ago #137434 by iLucato
skybax wrote: from what i see all is ok in that screenshot
Except that the TOPIC ICON below the SUBJECT isn`t showing.
13 years 11 months ago #137435 by TKtemp
you are using your own Kunena Template (copy of Blue Eagle), right?
It could be that you are not created your template in the right way.
Try to switch to Blue Eagle and let as know if icons show.
