Merged How do I setup Polls?
- sloanthrasher
I've searched the wiki, and looked all through the backend (I found where you allow polls in a category), and haven't been able to find how to get polls working. I saw one topic in the wiki that said to go to the plugins, but I don't see the polls plugin.
Thanks for any help!
Sloan
In the meantime let us try to help you here on the forum.
Polls are enabled on a per-category basis. You can choose if you want to enable polling in a category or not enable polling in a certain category but you must do this for each category that you setup. The default is to disallow polling.
Go to the Kunena Category Manager, select the category where you want to enable polls, then use the Settings tab to change the setting Allow Polls = Yes
There are some "global settings" for polls in your forum. These are located on Forum Configuration » Extra » Polls Settings. I hope this 5-second "tutorial" on how to setup polls helps.
i have enable the Poll but i not show nothing in the post tu PUT THE POLL????
you know why???
- Thank you received: 191
