Solved [Solved] Kunena Menu keeps showing after deleted.
13 years 11 months ago - 13 years 11 months ago #137261 by iLucato
Hi folks, I just installed Kunena 2.0.3 and deleted the Kunena Menu, which isn't needed for me once I use my own menus in my BluEagle layout. So, I have deleted first each item into the Kunena Menu, and later the whole Kunena Menu. There is nothing in the menu list or even in the trash can and the Kunena menu keeps showing.
How can it be? How to really delete it?
Thanks.
Last edit: 13 years 11 months ago by iLucato.
13 years 11 months ago #137262 by sozzled
The Kunena menu is just a Joomla menu and you control it with the Joomla Menu Manager. Maybe, in your case, you're picking up a cached version of you website or maybe you have ACP turned on? I have no idea why you're having problems.
13 years 11 months ago - 13 years 11 months ago #137289 by iLucato
Prety weird! The jos_menu and jos_menu_types had no info at all about them and them kept showing, even after cleaning the browser cache and Joomla.
Anyway I got to remove them by recreating the menu again as show in the video in your link, by the way, thanks for the link, and after that I deleted it again without deleting the main (Forum) item, just sub items. In other previous versions it was possible to remove all.
Thanks.
