Solved Kunena SEF problem
14 years 19 hours ago #136734 by klausveliu
I am a new user of Joomla 2.5 and Kunena.
Recently I am building a forum, but I have a problem when I enable
Search Engine Friendly URLs in Joomla.
The page on the forum main menu gives an error Kunena view 'index' not found.
This error comes with Search Engine Friendly URLs set to yes under kunena config.
When I set it to no it gives an error that the page it is not redirected correctly.
I have also renamed htaccess.txt to .htaccess on Joomla root folder.
Could someone help me with some tips?!
I am using the latest version of Joomla and Kunena
14 years 15 hours ago #136746 by sozzled
Replied by sozzled on topic Kunena SEF problem
I think you have a problem with the way you have setup your Joomla menu.
See Missing Kunena Menu which may give you some clues.
14 years 2 hours ago #136769 by klausveliu
Replied by klausveliu on topic Kunena SEF problem
I found a solution to my problem setting the menu type as external url and input
the url that kunena has without Joomla SEO enabled.
14 years 2 hours ago #136770 by sozzled
klausveliu wrote: I found a solution to my problem setting the menu type as external url and input the url that kunena has without Joomla SEO enabled.
In my opinion, I do not think that your approach is a particularly good solution. Your approach will cause you other problems. We recommend the use of the alias menu type and not the external URL type. But, if this works for you, that's good, and I will mark this topic as resolved. If you have other problems with Kunena as the result of what you have done, remember that we advised you not to do things this way.
Good luck and we hope you have a trouble-free forum.
