Solved Kunena Not Loading In Correct Site Template
14 years 1 week ago #136383 by 41global
Hello Kunena Family,
I have a problem that i cannot figure out at all. Simply just want Kunena forums to display in a sepearte site template i've built. I have to 2 templates, one for the homepage and the other for all other links. The initial Forums link works using the correct template but once you click on a category/header it loads back into the default template instead of the other template i want. I have all links pointed to the correct templates and have tried everything i can think of.
Thanks N Advance
14 years 1 week ago #136384 by 41global
I resovled on my own, just had to set the template i wanted to default and all is working fine now.
Time to create page: 0.099 seconds
