Merged How to change the avatar in my fresh installation
i have a new fresh joomla 2.5.7 with kunena 2.0.2 installation for the time being just locally.
Before i try to upload to the server i check out that i can't find how to change the avatar.
I can login i can show my profile i have in the top-right corner i nice "edit"-button but i can't see how i can choose or change the avatar ( i mean the small picture like e.g my guru pic
I think maybe it's only possible if the site is on the server or do i need some extra extensions for the avatars???
thanx a lot for your help!
- Jiminimonka
- Elite Member
- YBAS!
http://cl.ly/image/3k3C362d182E
and i didn't install joomsocial or Community Builder!
i have, as i told i very fresh joomla 2.5.7 - kunena 2.0.2 installation, without any problems during the installation ...
where can i check if i have to disable/enable something?
many thanx in advance
navigate to Joomla Administration -> Components -> Kunena Forum -> Kunena Plugins and be sure that "Kunena - Gravatar Integration" plugin is disabled.
Hope this helps.
this solved my issue!
- bloodbruise
